Salta al contenuto principale
Lanciato nel giugno 2009 / processore Core 2 Duo da 2,53 GHz
170 Domande Visualizza tutte
Trackpad jammed, will not click
Hi. I have a MacBook Pro from mid 2009. I was on my way to class, when I dropped it. The padded case kept the screen and drive from being damaged, but there is a small dent on the aluminum casing that seems to have jammed the trackpad. I can still move the cursor, but for clicking and scrolling, I've had to borrow a mouse from our library. Is there any way to fix the trackpad so it can click and use multitouch again?
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Risposta Più Utile
This could take some serious metal work skills. or You can replace the top case. Here's the part: MacBook Pro 15" Unibody (Mid 2009) Upper Case and Trackpad
Here's how to install it: MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Upper Case Replacement
or you can remove the top case and see if somehow you can remove the trackpad and use a jewelers file or sandpaper disk on a Dremel type tool to remove where the metal is binding the trackpad.
or use a diamond cut off disk on a high speed dental rotary tool such as a "jack rabbit" to grind the trackpad from the top. Like this: http://www.dentalcompare.com/details/768... This is what I use: http://cgi.ebay.com/ws/eBayISAPI.dll?Vie...
Immagine MacBook Pro 15" Unibody (Mid 2009) Upper Case and Trackpad
Prodotto
$39.99
Punteggio 3
1 Commento:
complete answer +
da
Aggiungi la tua risposta
Special92 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 9
Tutti i Tempi: 2,058
