Question 2: Why is my laptop taking so long to charge?
My laptop is taking a longer than usual time to charge. What could be causing this?
Questa è una buona domanda?
A common reason why your device is not charging as fast or as completely as before is that there is an issue with the charging cable. To remedy this, try inspecting where the cable plugs into the laptop. Use canned air to clean both the cable and where it plugs into the device. If charging problems persist, replace the cable as it is likely broken. If you still can’t charge your device effectively, follow this guide to replace your battery as it is likely dead or damaged.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 12
Tutti i Tempi: 167
1 Commento
Student Question
da mayer
