Salta al contenuto principale
HP Compaq C700 Battery Replacement
    1. HP Compaq C700 Battery Replacement, Battery: passo 1, immagine 1 di 1
      • It is advised to work on the device only when it is powered off so as to avoid electrocution risks.
      • Turn off computer by pressing and holding the power button.
      Chiedi a FixBot
      Aggiungi Commento
    2. HP Compaq C700 Battery Replacement: passo 2, immagine 1 di 1
      • On the underside of the laptop, locate the sliding lock that keeps the battery in place.
      • Using your finger, slide the battery lock to the left to unlock the battery. Once the battery is unlocked, it is free to be removed.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
UMass Dartmouth, Team 5-6, Martin Fall 2016 Membro di UMass Dartmouth, Team 5-6, Martin Fall 2016
UMASSD-MARTIN-F16S5G6
3 Membri
12 guide realizzate
1Commento della guida
thanks - appreciate this advice as I wasn’t able to get the battery out and thought I was missing something, but then I just tried harder!
Albert Einstein - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 5
Ultimi 7 giorni: 15
Ultimi 30 giorni: 44
Tutti i Tempi: 1,788
