Salta al contenuto principale
Device and repair information for the Behringer Eurolive B212D speaker system.
31 Domande Visualizza tutte
Why does my behringer b212d cuts off when playing?
My behringer b212d music cuts off when playing and the volume is set around 1/2 to 2/3? The next day it comes back on. I notice if the volume is set real low the music does not cut off for a long time. I DJ, so I need the speaker to work like it was designed to do.
Questa è una buona domanda?
Punteggio 0
2 Commenti
My Beringer speaker keeps going low to high. How do I fix it. I already changed the fuse
da
I am experiencing this when I am playing a guitar and vocals through into the mixer. Suddenly my microphone went quiet then didn't have any output at all. I changed the cable and it was louder again. Then on another occasion the same thing happened again. This is a fairly new power amp but the speakers are old. Could it be that the speakers need replaced?
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
@jeffburt27 sounds like bad amplifier IC's. Use these guides to disassemble your amp and take a look at the circuit boards. Check the IC's for obvious damage. Post a couple of images of what you see with your question. For that use this guide. That way we can see what you see.
Punteggio 2
Aggiungi la tua risposta
Jeff sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 24
Tutti i Tempi: 1,324
