Salta al contenuto principale
2.26 or 2.4 GHz / White plastic unibody enclosure
645 Domande Visualizza tutte
MacBook completely dead! Make up spilt on it.
Macbook has had liquid make up spilt on the keyboard area. It has been dried and cleaned. But the computer will not start up. no sound, no screen, nothing. Any suggestion of what might have gone and how I could resolve this
many thanks
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Risposta Più Utile
It needs to opened to find the extent of the damage. You can use distilled water to wash the components if you let it completely dry. The keyboard may need to be replaced. Here's how to remove the upper case: MacBook Unibody Model A1342 Upper Case Replacement
Punteggio 2
1 Commento:
good answer +
da
Hi Paul,
opened it up and cleaned/dried it? or just the outside. if so was there any evidence of oily liquid. this needs to be completely cleaned off as detailed by mayer. if you do that and it is still dead it could be an issue with the oily make up in the keyboard/power button?
What colour does the magsafe connector show, if any?
Punteggio 0
Aggiungi la tua risposta
paul sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,593
