Salta al contenuto principale
L'Acer Aspire 5334 si basa su Windows 7 (64 bit), ha 3 GB di RAM, monta un processore Intel Celeron 900 (2,2 GHz) ed è stato distribuito nel gennaio 2008.
computer won't boot, hard drive error
can't seem to get my computer to boot up to windows logo, I keep getting this hard drive read error.
Questa è una buona domanda?
Punteggio 1
2 Commenti
Did The Computer Recently Get Dropped ?
da Condividi
yes my sister recently dropped.
da Condividi
Aggiungi un commento
2 Risposte
Soluzione prescelta
Ok. Since the Laptop Was Dropped. We Need To Check And See If The Hard Drive Was Knocked Loose From Its Tray. Whats The Exact Model Number Of Your Laptop. We Have Acer Aspire 5334 There Should Be Four Other Numbers. Most Likely Your Hard Drive Was Knocked Loose And The Laptop Cant Find It.
On The Bottom Of The Laptop There Is This Cover. Big And Long. Take A Screwdriver And Remove That Cover. Take A Look Inside And See If The Hard Drive Is Knocked Loose.
Immagine
If It Did. Just Slide The Hard Drive Back Into The Connector.
Let me Know What Happens :)
Punteggio 3
2 Commenti:
I Hope This Fixes It. Because Other Wise The Hard Drive Might Have Been Damaged. Does The Hard Drive Make Any Noises Upon Turning On The Laptop. Clicking, Ticking etc
da Condividi
thank you so much, i followed exactly what you did, and everything works just fine now.
da Condividi
what is the error message that hard drive is giving? Did you try to reinstall the Operating System? If you did, did you receive any error messages? If so what were they?
Punteggio 0
1 Commento:
I reinstalled operating system and everything works fine now. thank you
da Condividi
Aggiungi la tua risposta
gilson teixeira sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 8
Ultimi 30 giorni: 24
Tutti i Tempi: 4,453
