Salta al contenuto principale
This is the Insignia Flex 8, a versatile tablet created by Tianshi Digi-Lando that can connect to the internet, take photographs, and use apps.
How do you replace the charging port?
The charging port in the tablet where you plug in the charger will not hold the charging cable. It appears the prongs may be broken or loose.
Questa è una buona domanda?
Punteggio 3
1 Commento
great instructions could not be any better
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Joan, Check if your Flex 8 is under warranty, if you have to have it fixed by a tech., you will have to way your options to whether cost effective to repair, Flex 8 can be had pretty cheap now. I will post a link for tear down on your unit to enable you to access charge port and you can google search for a replacement part. Good luck.
Disassembling Insignia Flex 8 Circuit Board
Punteggio 6
Aggiungi la tua risposta
Joan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 9
Tutti i Tempi: 2,470
