Salta al contenuto principale
Disassembling Insignia Flex 8 Circuit Board
Cosa ti serve
  1. Disassembling Insignia Flex 8 Circuit Board, Circuit Board: passo 1, immagine 1 di 1
    • Turn off the power to your tablet to avoid injury.
    • Position the tablet so that the screen is face down and the power button is located in the upper left hand corner.
    • Hold down the power button for five seconds until the tablet powers down.
  2. Disassembling Insignia Flex 8 Circuit Board: passo 2, immagine 1 di 2 Disassembling Insignia Flex 8 Circuit Board: passo 2, immagine 2 di 2
    • Remove the back casing from the screen by sliding a credit card or a similarly thin but firm object in between the casing and the screen.
    • You may need to use a spudger to initially create separation between the screen and the casing.
    • Run this object around the perimeter of the tablet until there is separation between the casing and the screen.
    • Remove the back casing and set aside.
  3. Disassembling Insignia Flex 8 Circuit Board: passo 3, immagine 1 di 2 Disassembling Insignia Flex 8 Circuit Board: passo 3, immagine 2 di 2
    • Peel tape off of ribbon connectors. Starting at the power button, work clockwise around the tablet.
  4. Disassembling Insignia Flex 8 Circuit Board: passo 4, immagine 1 di 3 Disassembling Insignia Flex 8 Circuit Board: passo 4, immagine 2 di 3 Disassembling Insignia Flex 8 Circuit Board: passo 4, immagine 3 di 3
    • To remove the camera ribbon cable, lift the flap using a spudger.
    • Pull the ribbon directly back to release it.
  5. Disassembling Insignia Flex 8 Circuit Board: passo 5, immagine 1 di 3 Disassembling Insignia Flex 8 Circuit Board: passo 5, immagine 2 di 3 Disassembling Insignia Flex 8 Circuit Board: passo 5, immagine 3 di 3
    • Remove the second ribbon cable by prying up the black flap using a spudger.
    • Pull the ribbon cable horizontally directly away from the battery.
  6. Disassembling Insignia Flex 8 Circuit Board: passo 6, immagine 1 di 3 Disassembling Insignia Flex 8 Circuit Board: passo 6, immagine 2 di 3 Disassembling Insignia Flex 8 Circuit Board: passo 6, immagine 3 di 3
    • Remove the final ribbon cable by pulling back the two black tabs on either side of the ribbon cable.
    • Pull the ribbon horizontally directly away from the battery.
  7. Disassembling Insignia Flex 8 Circuit Board: passo 7, immagine 1 di 2 Disassembling Insignia Flex 8 Circuit Board: passo 7, immagine 2 di 2
    • Unscrew the thirteen 4.75mm screws around the perimeter of the tablet using a PH 00 screwdriver.
  8. Disassembling Insignia Flex 8 Circuit Board: passo 8, immagine 1 di 2 Disassembling Insignia Flex 8 Circuit Board: passo 8, immagine 2 di 2
    • Unscrew the four 3.75mm screws and plastic washers using a PH 00 screwdriver.
    • Lift up the circuit board.
  9. Disassembling Insignia Flex 8 Circuit Board: passo 9, immagine 1 di 1
    • Unscrew the final two screws that were underneath the circuit board.
    • These screws are near the charging port and USB adapter.
    • These screws are also 3.75mm and can be interchanged with the second set of screws only.
  10. Disassembling Insignia Flex 8 Circuit Board: passo 10, immagine 1 di 1
    • Lift the circuit board and black internal mounting piece away from the screen.
    • Set the circuit board aside.
    • Be careful of the soldered antenna as you separate the pieces.
    • Be careful of the soldered ribbon that is connected to the power source. This ribbon is fragile.
Conclusione
Altre 2 persone hanno completato questa guida.
2 Commenti
Whwre can i buy the new screen
Emmanuel - Replica
I don’t see the ssd, and way to upgrade the internal sad had?
William Henderson - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 4,931
