Why won't my camera focus?
My camera worked fine before, but now my images are coming out blurry. I have tried resetting the device and it seemed to not work. How can I get my device to focus again?
Questa è una buona domanda?
Hi,
If you are having issues with image clarity, make sure that the subject is not too far or too close to the camera itself. This may seem like a simple solution but it is often effective. Also check to make sure that nothing is blocking the lens and that it is clean. If these solutions do not work, try using your device in focus lock which can be enabled by depressing the shutter button halfway.
Hope this helps, and good luck!
Ultime 24 ore: 2
Ultimi 7 giorni: 6
Ultimi 30 giorni: 26
Tutti i Tempi: 1,912
