Why does my Philips Photoframe switch off right after it's turned on?
I'm using an old Philips Photoframe for a visual art project that I'm working on; it's worked fine over the past 2 days but then it started switching itself off after being turned on. It boots fine but just switches off while the home page is being loaded. Could I have turned power save on without knowing it (the photoframe worked the same time yesterday and the day before) or is there a genuine problem? The charging mechanism seems to be fine.
Questa è una buona domanda?
4 Commenti
I've tried using the reset button, but the Photoframe still shuts itself down during the bootup process.
da mudfacehenrylee
Hi, Does this happen if you have the charger connected or only when running on the battery? Is the Smart Power setting enabled or disabled? have you set the correct date and time?
da jayeff
@jayeff It appears to happen with both situations. The date and time haven't been set because I don't need them; I'm not sure if the Smart Power setting has been enabled or not because the Photoframe was working at the same times for the past few days.
da mudfacehenrylee
In addition, I can't check if Smart Power is on or not because the Photoframe switches itself off before the home page loads.
da mudfacehenrylee
