Salta al contenuto principale
The Roku 3 (Model: 4200) is a third generation streaming device released on March 5, 2013. Connect to any television or video display with correct input connections to stream available content.
Why is my remote not connecting to the Roku player?
I changed the batteries in my remote but it is still not working. My Roku does not respond even when I tried moving closer and made sure nothing was blocking the Roku player.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Make sure that the batteries are a fresh pair and have the same brand as each other. Using two batteries with different brands can cause one to empty before the other, leading to the remote not working.
Your remote may not be paired with your Roku device. Try re-pairing your remote by removing the battery cover and holding the pairing button until you see the pairing LED flash. If done correctly, a remote pairing notification should appear on your screen.
For additional information and troubleshooting support, check out the Remote section of our troubleshooting guide.
Punteggio 0
Aggiungi la tua risposta
Isobelle Espiritu sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 690
