Salta al contenuto principale
A corded, electric, 5 amp spiral saw power tool with a two speed motor by Rotozip. The device comes with a variety of drill bits, sanding and polishing wheels, and a carrying case.
4 Domande Visualizza tutte
Why is my blade attachment not spinning?
My saw didn't have any problems before I changed the blade, but now the attachment won't spin at all. I don't know what I could've done to break it, help!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Try taking the blade off and attaching it again. If it still doesn't work you might have a faulty attachment. Also, do you at least hear the motor spinning inside? If not, than it might be a more serious problem and you might need to replace the motor itself. Be sure to check out the troubleshooting page for the RotoZip rebel first. Here's the link
RotoZip Rebel REB01 Type 2 Troubleshooting
Punteggio 0
You did release the lock I assume after changing the tool bit?
Punteggio 0
Aggiungi la tua risposta
Lauren Russell sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,575
