Salta al contenuto principale
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
How do I increase memory to increase down stream buffer
I am down loading a movie from Netflix to MacBook and have
buffer every 10 mins. What should I do to correct this Problem?
Model Identifier: MacBook2,1
Processor Name: Intel Core 2 Duo
Processor Speed: 2.16 GHz
Number Of Processors: 1
Total Number Of Cores: 2
L2 Cache: 4 MB
Memory: 2 GB
Bus Speed: 667 MHz
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Risposta Più Utile
Netflix runs a quick speed test to determine the bitrate of your stream right before it starts to load the film. That's the "determining your video quality" part after you hit the "Play" button. Once the movie loads, if you press Shift-B on your keyboard (you may have to click in the black area around the movie display first), you should get a small dropdown menu in the bottom right of the browser window, showing bitrates for the different streams available for that title. You'll be able to manually select the stream you want from that list, and the title will reload at that bitrate.
Punteggio 1
1 Commento:
good answer +
da
Aggiungi la tua risposta
Georges Tchikovani sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 962
