Congratulations on getting the keyboard working by replacing the flex cable. I'm going thru a rough period where I've had 3 different Macbooks with keyboard/trackpad problems. I replaced 2 entire top cases (2007 Macbooks) and the problem went away, but now it's come back on one of the Macbooks.
Power button works, but keyboard and trackpad don't work once computer has booted.
With the 3rd Macbook, from 2008, it's a slightly different problem: the power button works and the Macbook boots fine, but the keyboard and trackpad don't work; external USB and Bluetooth keyboards and mice work. I thought it was a bad keyboard, but the keyboard from this Macbook works on another Macbook; and a working keyboard doesn't work on this Macbook.
So it looks like the Macbook has some problems re. the connection to the logic board. Do you think?
Any ideas greatly appreciated.
I've taken lots of Mac portables apart over the years, but these Macbooks seem to have very fragile keyboard connectors, whether it's the flex cable or the connector on the logic board.
How hard is it to replace the keyboard flex cable?
Where can you get instructions and/or video? Doesn't seem like they have it here - just the entire top case replacement.
I have a 2007 Macbook keyboard that I use when I have to replace keys. It suffered water damage, but all the keys have worked, so I don't know how badly it was damaged. If I could, I'd like to try the flex cable from this keyboard to try to repair the other one. If not, I'd try to find one or two on eBay.
Votato
Annulla
Punteggio
0
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
1 Commento
Jon,
You posted a good question. My 2.4 GHz. Macbook Pro A1260 now has that problem too. I was told by a Clickaway service center here in CA, that it gets caused by the Lithium-Ion battery getting hot from it's older age, and being over charged, that caused the battery to get fat on it's top and bottom sides. The enlarged upper side presses against the board, next to the battery, that controls the keyboard, track pad and mouse button. They said that the only way to fix this is to get a replacement upper case. I haven't tried it yet.
Did you or anyone else try it?
da Alan Craig
