Salta al contenuto principale
The Alias is a USA-exclusive midrange clamshell QWERTY basic phone released by Samsung in 2007, for use on the Verizon network. Identifiable by model SCH-U740.
2 Domande Visualizza tutte
Does anyone know the battery pinout for Samsung SCH-U740 battery?
My wife picked up a used phone, Samsung Alias SCH-U740, for my 13 year-old son. It didn't have a battery so she bought a used battery and a charger.
The battery doesn't seem to charge and the phone won't power on. After being plugged in for about an hour, I checked the voltage on the battery with a multimeter. I can't get any voltage on any of the pins.
I'm trying to find the battery pinout so I can connect a power supply to test the phone.
There are 3 pins on the battery / phone. The battery shows a + sign next to one pin and a - next to the other side but what is the middle pin for?
Thanks,
Glen
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
The middle pin is for the battery sensor, the reading your phone gets to show you that pretty little battery bar. Hope this helps!
-Stelios
Punteggio 1
1 Commento:
Sounds like a good answer :) So if there is no power between the + and the - your battery may just not be working or your charger is defect. Check the output on your charger to make sure that it is working. Good luck.
da
The problem was that the phone wouldn't charge. So I was trying to determine if the battery, charger, or phone was bad.
I took a chance and connected a battery from a different phone using jumper wires to the pins on the phone. I connected positive to the pin corresponding to the + sign on the battery (obvious enough, right?) and the negative to the other outside pin (this was a bit of a guess). I left the middle pin disconnected.
Wowza! The phone turned on! This proved the phone worked.
Since the battery wouldn't charge through the phone, I wanted to try to charge it another way. I connected a 5V AC/DC adapter to the battery pins using tape to hold the wires on the battery. I let it charge for about 20 minutes and then installed the battery.
Yippee, it started up. So the phone is good and the battery is good. There must be something wrong with the charging circuit.
Sure enough, I took apart the phone and found the charging port was broken loose.
Anyway, we bought another phone with a broken screen to use as a charger. Then we can just swap the batteries.
I bought some supplies to try to resolder the charging port. It's really small but should be possible. Look at soldering tutorials on www.sparkfun.com
Punteggio 1
1 Commento:
Good deal Glen--now would you please accept your answer so the question may be closed. Thanks +
da
Aggiungi la tua risposta
Glen Meiring sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 5
Tutti i Tempi: 7,167
