Salta al contenuto principale
The aluminum PowerBook G4 was released by Apple to replace the previous titanium-body model. The 12" and 17" versions debutted in January 2003 with the 15" version following in September of that year.
solution to fix damage PowerBook keyboard
powerbook G4 keyboard can't type well.
the problem is when I type any key it will repeat rapidly like eeeeeeeeeeeeeeeeeeeeeeeeeee or aaaaaaaaaaaaaaaaaaaaaaaaaa
the button will repeat it self.
Before I'll change new keyboard part is any solution to fix it ?
Questa è una buona domanda?
Punteggio 1
2 Commenti
Was there a spill?
da
Would you give us the last three letters of your serial number?
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
It may be that the keys are just a sticky. I would remove the top case, pop all the keys off of the scissor assemblies, and thoroughly clean the scissor mechanisms, the rubber "boots", and the keycaps themselves. The area under the keyboard can get pretty sticky after several years of use.
Also, if you find that cleaning doesn't resolve your issue, you don't need to buy a whole new top case. You can save money by buying a replacement keyboard, sometimes you can find one on ebay that doesn't have keycaps, those keyboards are even cheaper.
Punteggio 1
Aggiungi la tua risposta
KataBoy sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,440
