Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1688/A1633. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 32, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
6S backlight problems after screen replacement
Ok so I replaced a screen on an iPhone 6S this morning and I broke the proximity sensor flex cable. I went ahead put the phone back together to wait on the sensor to come in, but after reassembling the the phone, the backlight is not working. Is this because of the proximity sensor cable being broken or did customer get a junk screen from Amazon? I've checked everything else I can think of.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Did you unplug battery and use Anti Static? If not blown Backlight Filter
Punteggio 1
1 Commento:
Anti-Static isn't really an issue but essential to have.
I agree it's most likely a blown backlight filter as a replacement screen with no backlight is pretty rare even if cheap quality.
da
Aggiungi la tua risposta
JC sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 143
