Location of Bluetooth Card?
Where is the Bluetooth card located in a Glossy Screen 2009 MacBook Pro ?
Is it located with the WiFi card ?
Update (09/05/2016)
WiFi Card blown by Bit Torrent large download. Unfortunately Replacement S/H Card from USA. has a faulty Bluetooth section, on external test.
Hence the enquiry to confirm that Both are on the One Card & Not Elsewhere.
Questa è una buona domanda?
3 Commenti
Apple has three different models here. Can you give us the exact model info. Plug in your full serial number here: EveryMac Lookup. Then paste the systems URL into your question so we can isolate which system you have.
da Dan
Your system specs: MacBook Pro 15" 2.66 GHz Core 2 Duo
da Dan
Make sure you got the correct part here. If you got the antiglare version of the Airport board you got the WiFi only version.
da Dan
