Salta al contenuto principale
MacBook Pro 15" Unibody Mid 2009 Bluetooth Board Replacement
Cosa ti serve
  1. MacBook Pro 15" Unibody Mid 2009 Bluetooth Board Replacement, Lower Case: passo 1, immagine 1 di 1
    • Seven 3 mm Phillips screws.
  2. MacBook Pro 15" Unibody Mid 2009 Bluetooth Board Replacement: passo 2, immagine 1 di 2 MacBook Pro 15" Unibody Mid 2009 Bluetooth Board Replacement: passo 2, immagine 2 di 2
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
  3. MacBook Pro 15" Unibody Mid 2009 Bluetooth Board Replacement, (Anti-Glare Option) Bluetooth Board: passo 3, immagine 1 di 2 MacBook Pro 15" Unibody Mid 2009 Bluetooth Board Replacement, (Anti-Glare Option) Bluetooth Board: passo 3, immagine 2 di 2
    • Disconnect the Bluetooth cable by pulling the male end straight away from its socket.
    • Pull the connector parallel to the face of the logic board, not straight up.
    • Use the flat end of a spudger to pry the Bluetooth antenna cable from its socket on the board.
  4. MacBook Pro 15" Unibody Mid 2009 Bluetooth Board Replacement: passo 4, immagine 1 di 2 MacBook Pro 15" Unibody Mid 2009 Bluetooth Board Replacement: passo 4, immagine 2 di 2
    • Remove the two 8 mm Phillips screws securing the Bluetooth/camera cable retainer to the upper case.
    • One of the screws may remain captive in the Bluetooth/camera cable ground loop. If replacing the display, be sure to transfer this screw to the new unit.
    • Lift the Bluetooth board/cable retainer assembly out of the upper case.
  5. MacBook Pro 15" Unibody Mid 2009 Bluetooth Board Replacement, (Anti-Glare Option) Bluetooth Board: passo 5, immagine 1 di 1
    • Remove the single Phillips screw securing the Bluetooth board to the retainer.
    • Lift the Bluetooth board off the retainer.
Conclusione
Altre 3 persone hanno completato questa guida.
4Commenti sulla guida
is there a newer bluetoth 4.0 / 4.1 board available for the mid 2009 15'' model?
roblamper - Replica
I second roblamper's question... Yosemite/iOS 8's new "Handoff" as well as "OS X+iOS AirDrop" feature(s) appear to be thwarted on the Mid 2009 MBP due to the existing Bluetooth hardware limitation. I suppose even if there is a Bluetooth 4.0 LE replacement available there may be some .kext changes required. Regardless, baby steps... First things first and that is discovering suitable hardware (-;
honDA9xsi - Replica
Does anyone know where the bluetooth board for a NON ANTI-GLARE model might be found? I'm presuming that I have to lift the logic board to get to it as I can't see anything from the underside.
Hope you can help!
Thanks
John
jpmolesworth - Replica
Where do i find that Cable?
pkremsi - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 46
Tutti i Tempi: 18,159
