Hi
Iv seen many dysons before and it tends to be 1 of 2 things
1there is damp dust inside of the cyclone
2the filter needs washed(if you tell me the model I can further help you with it)
Chances are that if you left it for 4days to dry it’s the filter needing washed
EDIT:I have see that you am have washed the filter from previous messages and that usually means it’s damp dust that has gathered bad smells
So you can do one of 2 things here
1)dismantle the cyclone ,it’s no too hard but it’s not for everyone
2)remove the cyclone unit from the machine and then the bin from the cyclone and get a big bucket and fill it with hot soapy water and shake and fill the cyclone with the water to clean the inside
Optionally you can use a tap or a garden hose to wash the inside with the cold water and leave to dry for a while until dry
If you have any questions please ask
Votato
Annulla
Punteggio
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
1 Commento
Which Dyson vacuum is it?
da mayer
