Trouble connecting to television.
How can I connect my Asus Transformer to a standard TV?
Questa è una buona domanda?
Hi,
Your Asus Transformer has a micro HDMI port that you can use to connect to a TV.
The TV needs to have a HDMI connection available. These connections (ports) can be found, depending on the make and model of the TV, on the back, on either side or behind a panel on the front of the TV.
If it is a full size port that is not a problem. All you need then is a micro HDMI to HDMI cable to connect between the two devices.
This is what the different size HDMI cable plugs look like.
This is what it might look like on the back of your TV
If you do have a HDMI port available on your TV, connect the Asus (make sure it is switched off before you do this) to it with the appropriate cable, switch the input of your TV away from the antenna to the correct HDMI input, (if you have more than one) using the input button on the remote control of the TV and switch on your Asus, you should see on the TV what is being displayed on the Asus.
If you need more assistance, please reply with the make and model number of your TV so that you can get a detailed answer on how to connect the two devices together.
it doesn't work! i follow your instruction but it won;t work.
Hi,
Did you make sure that you selected to correct HDMI input on the TV?
Did you press Fn + F8 on the T100 to select one of the dual display options?
did both thing and my computer still doesn’t connect :(
It doesn't work for me either. I tried to resize my graphics and pressed the fn8 button. I'm so frustrated already. Help!
=== Update (05/30/2020) ===
I use a Sony Bravia tv
Doesnt work for me either :/
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 14
Tutti i Tempi: 12,154
