Salta al contenuto principale
Repair guides and troubleshooting for the Bodum Bistro Electric Blender Stick. These immersion blenders can reach speeds up to 20,000 rpm.
4 Domande Visualizza tutte
Motor working but blade not rotating
Motor is working as sound is coming but the blade ia not rotating and hence blender isn't working..
Is there any shop in botanique, brussels where I can get it fixed?
Thanks.
Questa è una buona domanda?
Punteggio 2
1 Commento:
Hi, if you still have your Bodum Bistro Electric Blender Stick but youre no longer using it, I would be interested in buying the small blade from you, as I have lost my own, and Bodum no longer provides parts (nor does any other store I contacted).
da
Aggiungi un commento
1 Risposta
Hi, you don’t need any fixing store to fix it. Probably the issue with the metal pin, which brings rotation power from the motor to the blades. Check how I repaired my blender, easily on repair your blender, easy fix video.
And it will costs you few cents, in the repair shop they will charge you at least 10$ for the fix.
Punteggio 0
Aggiungi la tua risposta
Foram Shah sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 19
Tutti i Tempi: 2,279
