Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
How can I repair circuit line?
http://imgur.com/KugjvqC
The big thing is ground.
Directly to the left, those two pads had a capacitor on it.
Top pad is supposed to be ground, bottom pad is not.
It looks like bottom pad may have access to ground plane.
Is there a method to fix something like this?
Originally this problem was a short on the battery line, couldn't find the problem but then found that little pad. I can't really test resistance because the pads are too small for my multimeter to touch. And my multimeter isn't very good anyway.
How do I separate that pad from having access to ground?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
我不太明白你想说的是什么,但是电容在逻辑电路中是耦合作用的,一般情况拆掉也是可以的。不会影响功能的使用。如果你的万用表不好,我建议你先买好工具再维修。
Punteggio 0
1 Commento:
@bdw
This is translation.
I do not understand what you want to say , but capacitive coupling is in the logic circuit , in general removed is also possible. It does not affect the use of functions. If your meter is not good , I suggest you first bought and then repair
I think you are confused because you are saying if you remove capacitor short shold be gone?
Usually the case, but this time whatever is separating the ground plane from the pad isn't there and and the pad itself has access to ground.
da
Aggiungi la tua risposta
Aaron sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 70
