Salta al contenuto principale
L'LG K7 è uno smartphone rilasciato da LG nel febbraio 2016 con sistema operativo Android 5.1.
No Command Can't factory Reset
I have a Android LG K7 and today it went to go update its systems and said error and now its stuck on this screen where the little android man is flat on his back with "No Command" at the bottom of the screen I've tried erasing the data to see if that works but it doesn't now I'm trying to get it to go to the factory reset menu in hopes that will work but it doesn't even go to that menu at all the only thing i can get is the data reset, the phone seems to be in a constant loop it turns off and turns back on to only go back to the same screen if you leave it by itself i don't know what to do please help me
Questa è una buona domanda?
Punteggio 5
1 Commento
I cant factory reset my phone my robot is laying down when I reset it and it goes away I cant see it anywhere how do Iget it to stay on my cell phone when im in a reset
da
Aggiungi un commento
7 Risposte
Risposta più utile
I have the same problem pls if some one know how I really going to appreciated.
Punteggio 2
http://forum.xda-developers.com/android/...
Had the same prob guys, do this to the exact letter and this will fix it.
Punteggio 2
I have the exact same problem. Happened today.
Punteggio 1
1 Commento:
what should i do?
da
This happened to me just now. :/
Punteggio 1
1 Commento:
how to repair blackview ultra a6 no command when i turn it on?
da
this happened to me just now
Update (08/11/2016)
i don't know how to repair my phone problem.
Punteggio 0
1 Commento:
who know how to repair my phone prolem? I really going to appreciated.
da
I never got mine fixed after trying several solutions. Apparently, there is no recovery options for our model of phone. .. BUT if hold down the power button and the volume button to turn it on, when the logo flashes, you let go of the power button briefly and then press it again (while still holding that volume down key in the process) and the factory reset option will come up. I hit the factory reset option but my phone is on a boot loop, so when I try to factory restore it, the phone crashes and resets itself. But hope everyone else's isn't in the boot loop and can at least restore theirs to factory settings. I just threw my phone in the garbage and went down to boost mobile.
Punteggio 0
Right now the Update Affected our LG K7 No fixes yet i had to get mine Replaced By carrier
Punteggio 0
1 Commento:
Was your replacement free?
da
Aggiungi la tua risposta
Marquise sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 20
Tutti i Tempi: 10,773
