Salta al contenuto principale
Windows 8.1 failed after update?
Hello, I recently bought ssd and installed windows 8.1. after few days it automatically installed 127 updates, although it froze on "shutting down" for few hours so I restarted it. It gave me BSOD so I turned it off and got myself usb with recovery software to repair windows. But now Windows won't even boot to safe mode(shift+f8) nor normally. It just loads and boots to black screen. With SSD plugged in with failed windows 8.1 it won't even boot from USB! Although once I disconnect the ssd sata connector, it launches and recognizes bootable usb. I tried even disconnecting ssd while having my PC on booted from usb(windows 8 installer) but once I connect ssd sata back in - it freezes!!! Could someone help me quickly??
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Hi there,
It looks like you're having problems booting up your PC after installing an update. I would like to know if you have tried to force restart your computer, and see if the issue persists. Have you tried to start your computer in safe mode? You can also check this '''article''' on how to get to Windows Startup Settings which allows you to start Windows in a different advanced troubleshooting modes to help you locate and resolve problems on your computer.
As there’s problem in booting from your hard drive, you may check out this article to see if it is helpful.
Hope this info helps you. Thanks!
Punteggio 0
Aggiungi la tua risposta
Albertas Ensteinas sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 57
