Salta al contenuto principale
The third generation of the Toyota Camry in all markets outside Japan. 1991-1996 was also called the XV10 series of Camry vehicles.
79 Domande Visualizza tutte
New AC compressor now overheating. Help!
I have a 96 Camry V6 3.0 I bought for 400 dollars. But the car has ran great and I have taken care of it. 223,000 miles on the car. I just put in a new AC compressor and now I'm overheating. I know the AC draws alot of power but what can I change now to stop overheating? Thank you.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Probably not an answer but make sure the belt is at proper tension. Make sure the water pump pulley if fully engaged and turning. See if there is a difference when the ac is on, and when its not on.
Punteggio 0
2 Commenti:
The tension is good, the fans are ruining strong, I did a coolant flush a month ago. I looked about an hour ago and I was really low on coolant. I filled her up then drive her for an hour and she kept a good temp. I know I filled her full when I did the flush. It was over 100 degrees today. Maybe just to hot for an old car but I changed the compressor to have ac on days like today. Thank you for the reply.
da
No problem. I just assumed your coolant level was correct. Good to see you keeping and older car going.
da
Aggiungi la tua risposta
BRANDON S RHEA sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 6
Tutti i Tempi: 211
