Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
Top of phone overheating after replacement
Hi guys, so I just replaced my screen with a new one and everything is working perfectly (camera, light sensor, speaker) however it gets very hot right where the front speaker is at the top... How can I fix it? I double checked and everything is positioned in the right place.
Thanks !!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Well heat comes from something short circuiting, and right above the speaker is the battery. When you replaced the screen did you open the battery input cover? If you did there where rubber things on top of some of the inputs also on that board. If those where removed it could cause heat. Keep us posted.
Punteggio 1
6 Commenti:
Hey, I didn't touch the battery at all during the replacement... Just swapped over the components at the top with the camera, earpiece and ligh sensor.. So the heat is not coming from the bottom speaker I actually meant earpiece, and surrounding area. The rest of the phone stays cool to touch.
da
Did you get a response on this?
da
I have the exact same problem. Did you manage to solve it??
da
Might be a damaged front camera ribbon cable assembly.
Replacing it is worth a try, but it's weird if everything on the front camera assembly works fine like, ambient light sensor that adjusts auto brightness, proximity sensor which allows the phone screen to turn off when the phone is placed near your ear on calls, front camera, earpiece speaker used for calls without speaker mode activated.
da
The only things that are located there are the Facetime camera, some sensors and the earpiece speaker. The only one of them that could possibly draw enough power to heat up would be the speaker. That's also the easiest thing to not line up right.
I have never personally seen it happen but it would make sense if the speaker wasn lined up with some type of short or possibly the flex cable connection got damaged when it wasn't lined up right and somehow shorted.
I would:
1. Make sure the speaker is seated corrected and the flex is lined up
2. Make sure there is no tear in the flex
3. Replace the flex
That flex is probably the easiest thing to replace on an iPhone, so it shouldn't be a big job.
da
Mostra 1 altro commento
Aggiungi la tua risposta
Ioana pal sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,235
