Salta al contenuto principale
Annunciato nel marzo 2015 e lanciato il 10 aprile 2015, il Galaxy S6 Edge è la versione con schermo curvo dell'S6, il modello al top di gamma di allora.
237 Domande Visualizza tutte
Dropped by mistake phone in toilett.
Hi...
As stated, my S6 Edge has taken a bath in the toilett.
The phone was not starting for 1 day.
Now the phone is starting only then battery charger is connected.
The phone say that the battery is 100 % charged.
Then I disconnect the charger then running, it just dies.
Sometimes when I try to boot I have to do Volume Down + Hometab + On buttom and then choose cansel then screen boots up. Then the phone boot up.
I have done a faktory reset.
I wonder, which parts is most likely to be changed?
Regards
A clumsy person :(
Update (07/10/2016)
Hi again...
I have now cleaned the phone inside and changed battery and charger port.
Problem still exist.
Any other solution I might try?
/NBonline
Update (07/16/2016)
Hi again...
Tested with disconnecting the battery from motherboard for 6 hours .
When i connected it again I could start the phone without charger and it show probably the right battery status.
After abaout 6 hour the phone went dead again. It worked perfeclty until then.
Time to test it again and see if it get any better.
/NBonline
Questa è una buona domanda?
Punteggio 0
4 Commenti
Thanks for quick responce!
I will take it appart and clean as you advised.
Do you think anything else appart from battery should be replaced?
/NBonline
da
Not until you know what you have after you clean it and replace the battery. That is truly only the beginning of the trouble shooting. It give you a clean starting point.
da
Ok, thanks again for fast answer. I will do a cleaning and replace battery, then will se what happens.
da
Hi again...
/NBonline
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
@nbonline I totally agree with @galmoham At this point you have to treat it like any other water damaged phone. The very first thing you want to do is to not try to restart the phone. This may further damage your phone. The next thing to do is to clean it. Disassemble your phone using these guides Remove all EMI shields from your phone, then clean it with +90% isopropyl alcohol. Follow this guide, and even so it was written for an Apple iPhone 3G all the points are still pertinent to your phone. While you clean your board, check for any obvious damage, like burned or missing components etc. When it is properly cleaned, replace the battery. All these steps are to avoid delayed failure caused by corrosion. Best way to clean it would of course be through an ultrasonic cleaner, so you may consider a professional service . Once all this is done, reassemble your phone and reevaluate.
Punteggio 2
i think you should disassemble and clean inside with rubbing alcohol ... if you have done this earlier when this happen you wouldn't have had any problem because the phone is waterproof
Punteggio 1
2 Commenti:
I dropped my phone in curry and I turned my phone on it was working for 5mins and then stopped working I have left it upside Down to see if it drips out and it still won't work how can I fix this problem?
da
drop the phone in a bag of rice (cover it completely with the rice) for about a day and see
da
Aggiungi la tua risposta
Niclas Brorsson sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 207
