Salta al contenuto principale
replace a a1212 with an A1261
hello, I have a macbook pro with the logic board a1212 broken , I would like to know if i can replace it with a A1261 (to have such a powerful pc).
thanks
Questa è una buona domanda?
Punteggio 0
4 Commenti
or another more powerful, as the model a1229
da
Why do you think the logic board is broken?
da
the screen remains white after power, and did not work any recovery procedure (pram reset etc.)
da
you are right, thanks a lot!!!
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
No sorry they are not cross compatible , for starters the screens are different a1212 uses CFL bulb , while the a1261 uses LED bulb.
Punteggio 1
1 Commento:
thank you, and whit a1229?
or any more powerful?
da
Risposta Più Utile
A white screen usually indicates a failed hard dive. Try disconnecting the drive from the logic board and booting from the original system installation optical disk.
Punteggio 2
2 Commenti:
da
Then you accepted the wrong answer ;-)
da
Aggiungi la tua risposta
davidegatt sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 166
