Salta al contenuto principale
Repair guides and support for Panasonic's Viera line of televisions.
417 Domande Visualizza tutte
No power to TV
Panasonic Viera plasma TV Model THP42X50Z:
Went to use remote like normal, wouldn't turn on. Thought flat batteries, went to do it manually...nothing. There is not even the red standby light. Have checked power socket, other items working fro there (stereo, dvd player) Help please!
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
Soluzione Prescelta
@sunsurfer111 this could be as simple as a blown fuse but could also indicate a more serious problem with the power board. You'll have to remove the back of the TV and check the fuse on the board with a multimeter for continuity.
Punteggio 7
6 Commenti:
Ok I've done that the fuse is fine.
da
Mavis Senior okay now I am confused? Who are you ;-)? Anyhow. You have the same TV? Describe your error as well as all the things you have tried so we can try to help you as well.
da
Thank you, you helped me eliminate some things, so I could go on with my diagnoses.
da
Thank you so much, My TV is working
da
My tv will not turn on after a power outage. Has happened before and has taken 3 to 5 days to turn on...help!!!???
da
Mostra 1 altro commento
Had a blown fuse. The fuse was replaced and TV is working again.
Punteggio 0
Aggiungi la tua risposta
sunsurfer111 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 23
Tutti i Tempi: 8,139
