Salta al contenuto principale
The Samsung Galaxy Note 4 is a cellular smartphone that was released in October 2014. The Galaxy Note 4 Model Number is SM-N910, SM-N910A, SM-N910T, SM-N910V, or SM-N910R4 for American variants.
256 Domande Visualizza tutte
note 4 screen not turning on but buttons still light up
After opening up my note 4 and adjusting the gps antenna on it when i put it back together the screen no longer turns on but the buttons still lights up indicating that power is running to it can you guys give me a brief idea of what component i need to check out to fix this?
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The LCD cable plugs in behind the logic board. It probably went loose if you lifted up the logic board. You simply just need to plug it back in. It's a bit tricky to do.
Punteggio 3
2 Commenti:
do u have a picture of which ones?
da
Check step 6 of this guide. You should be able to plug in the two cables. I think one is for the S-Pen and the other is for the digitizer + lcd.
Samsung Galaxy Note 4 Display Assembly Replacement
da
Aggiungi la tua risposta
baconlover53 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 4,310
