Introduzione
Use this guide to replace the display assembly on your Galaxy Note 4.
Cosa ti serve
Panoramica Video
NOTE: It is suggested to remove the battery, S Pen, SD Card, and SIM card (if your phone uses a SIM card).
Begin by heating the edges of the screen. The adhesive on the Galaxy Note 4 is weaker than on newer generations and will release easier, requiring less heat and prying.
Slowly work your way around the edges of the screen with a pry tool or pick.
Work your way around the top and sides of the device, and very carefully approach the adhesive on the bottom of the phone. The Galaxy Note 4's touch-sensitive pads lay in the way of your opening picks and it is very easy to sever them.
Notice 1: The adhesive is in the red line.
Notice 2: If you insert the spudger from right side, keep the length of the tool in less than 2.2cm, which is for avoiding damaging the home button flex.
Notice 3: If you insert the spudger from left side, keep the length of the tool in less than 4.4cm for the same reason.
Altre 161 persone hanno completato questa guida.
42Commenti sulla guida
Here in our tech community we have been discussing the foil under the LCD. We are doing more testing but there might be a connection with the foil functioning in conjunction with S-Pen and AirView. Can anyone confirm this?
Yes, the foil permits the s pen to function. If you have the part of the foil that was riped off you can tape it back.
the foil itself has nothing to do with the functioning of the spen. It is for heat dissipation
