Salta al contenuto principale
The Nintendo GameCube Controller DOL-003. Released November 2001, compatible with Nintendo GameCube, Nintendo Wii, Nintendo Wii U, and Nintendo Switch. Repair for this device is straightforward and requires only common tools.
How can I replace the "electronic" joystick component?
My controller's electronic joystick component is loose and goes rogue when I plug it in, how do I obtain the electronic part and how do I solder it to the controller's pcb?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
@gio_ex that will depend on which part it is. Take some pictures and post those with your question. Use this guide for that. Most of the part requires soldering and use these guides to familiarize yourself with the process. After that you need to practice a lot.
Punteggio 1
Aggiungi la tua risposta
Giovanni sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 348
