Salta al contenuto principale
Guide per la versione Wi-Fi dell'iPad Mini 2. Annunciato il 22 ottobre e introdotto il 12 novembre 2013. L'iPad mini 2, noto anche come iPad mini con Retina Display, ha tutti i pixel dell'iPad Air in un più piccolo fattore di forma da 7,9"
Charging Problem - not charging
Hi
I have an ipad mini 2 - model A1489 - when plugged in on charge it shows the lightning indicator, showing it is charging, but never gets past 2% and will switch off straight away when its disconnected, which indicates its not holding charge either.
I've opened it to inspect it, looked at the circuit board under a microscope and can't see anything missing. This is, by the way, the first time its been opened.
Here's the fun part, its been used by a child so is likely to have been dropped, although no visible signs of damage or water damage. whilst on charge it reboots every 5-10 minutes too.
Could this be a worn a battery?
I've tried several different cables and I am using a good charger.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Sounds like a faulty battery to me.
You'll have to get it replaced.
Just in case below :)
You can get the part from here:
iPad mini 2 Battery
Guide on how to replace it:
Sostituzione batteria iPad Mini 3 WiFi
Immagine Replace a battery compatible with iPad mini 2 A1489 and A1490 model tablets. 23.8 Watt Hours (Wh). 3.75 Volts (V). Battery model A1512.
Prodotto
iPad mini 2 Battery
$31.99
Punteggio 2
1 Commento:
Thats what i was thinking, it comes on with charge then dies as soon as you disconnect it. Thanks for your reply
da
Aggiungi la tua risposta
Dan Hurst sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,598
