Why does my screen display flash then the device restarts?
While in use without being attached to charging cable. Attaching the charging cable can stop the screen flashing usually. The battery charges and seems to hold a charge OK. The tablet has never been dropped or exposed to water.
Questa è una buona domanda?
Punteggio
0
Hi, If you don't have this problem at all with the tablet when the charging cable is attached (is this correct?) then it seems as though the battery may be the problem. How long have you had the tablet and do you normally use it on the battery? It may be that it is starting to fail. Even rechargeable batteries have a life span.
da jayeff
