Salta al contenuto principale
Third generation of iPad with Wi-Fi, released on March 16, 2012. Model Number A1416. Repair requires heating and careful prying.
154 Domande Visualizza tutte
My I pad screen shows like X-ray
Hi!! friends today i atempt to change my ipad 3 front screen, i was doing fine, after i make all, i checked brfore closing so it was coming apple logo and was on nicely. than i fixed my lcd screen and i try again to make on if everything still fine, than it showes no apple logo and its just black and and white colors like xray.
it will be great help if you can help me.
thank you
thakur
Update (05/10/2016)
I Click my home button fast but did not work I check all connection inside its looks very fine. What should I do now I will be so thankful please help me.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Click your home button 3 or 4 times in a row fast. This should fix your issue.
Punteggio 0
3 Commenti:
Hi Brian thank you I try but it's come only Shri sound.
da
I click fast home buttom doesn't change
da
Sorry for the late reply. Are you sure you didnt damage the lcd in any way? Damaging the LCD doesnt necessarily mean a crack. I have damaged an iPad Mini lcd once before which gave this xray look you speak of. Also, here is something else to try.
1) Go to “Settings” and then tap “General.”
2) Tap the “Accessibility” option.
3) There is an “Invert Colors” option that you can toggle on/off with a swipe.
da
Aggiungi la tua risposta
thakur sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 25
Tutti i Tempi: 1,259
