Salta al contenuto principale
The Mac Pro First Generation is an Intel Xeon-based workstation computer manufactured by Apple Inc. The first generation model includes the machines from 2006 through 2008.
Master and slave disks
I replaced the original hard drive on my Mac Pro early 2008 with an SSD drive, which made a big improvement the speed of the machine. I now have OSX 10.5 (for legacy software use), Boot Camp and Windows 7 installed on a spare 320GB hard drive and the original 500GB hard drive as a backup disk.
The problem is, Windows will only start up if I remove the original 500GB hard drive, presumably because it's still the Master drive and the others are slaves. How can I make the SSD the Master drive, or is the problem somewhere else?
Questa è una buona domanda?
Punteggio 0
2 Commenti
his sounds like a boot order problem. as mayer says the master slave issue went out with the older drive. SATA has no issue there
da
this thread from the apple forum may prove useful https://discussions.apple.com/thread/336...
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Master and slave drives were issues related to IDE, ATA & PATA drives, SATA drives do not have this issues. So look elsewhere.
Punteggio 4
Aggiungi la tua risposta
Soane sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 716
