Salta al contenuto principale
Nel 2012, Sony annunciò che la società avrebbe rilasciato una nuova versione della sua console PlayStation 3 del 2006. La nuova console fu chiamata PlayStation 3 Super Slim ed è identificata dal numero di modello CECH-4000. La PlayStation 3 Super Slim (CECH400x) è la terza versione della console per videogiochi PS3 prodotta da Sony Computer Entertainment. Fu lanciata sul mercato il 25 Ottobre 2012.
211 Domande Visualizza tutte
Domanda Chiusa
Why is my Playstation 3 Super Slim freezing?
My PlayStation 3 Super Slim freezes on the XMB. Is there a way to fix this that does not involve replacing any parts? I am not very comfortable with taking the device apart and would not even know where to start. Any help or suggesting for fixing it would be greatly appreciated. Thank you!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
The best way to resolve this issue will be to restore your device. To do this, check out iFixit's troubleshooting page for the PS3 Super Slim. It will guide you through some easy steps to fix this issue without taking your device apart.
I hope this helps!
Punteggio 0
This could be because the disc is dirty, which means you simply need to clean your disc. If that isn't the issue, it could also be because of damaged file, which would require you to restore the file system (restore file system instructions can be found in the troubleshooting page). If that doesn't work either, it's likely that there's an issue with the laser lens, which would require a lens replacement.
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 3,288
