I can barely see the screen
I can barely see the screen and adjusting it makes no difference
Questa è una buona domanda?
shawn sounds like your backlight has failed. Most common cause for that are bad capacitors. Your monitor does not have a separate inverter but it is part of the power board. Start by disassembling the monitor and take a look at the boards and the caps. Check for bulging or leaking caps. Post some good images of your boards with your original question. For that use this guide. Since I only have the assembly instructions, substitute the assemble with disassemble
I went ahead and tore it apart right after posting the question and not one of the caps had much for capacitance,they was toast.
Did you replace those?
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 18
Tutti i Tempi: 541
