Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1688/A1633. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 32, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
2690 Domande Visualizza tutte
iPhone 6s died after a night charge
Yesterday a cumstomer brought a dead iPhone 6s after a night charge, the phone is only 4 months old and apple refuse to accept the phone for a repair or swap.
I advised her to contact Apple customer service, since the phone is only 4 months old.
She told me that she’s no longer wanted to return the phone to the Apple store, because how they treated there customers.
Before I explain the problem, the phone has never been opened before and not touch with water.
I opend the phone and I start with test the battery with the multimeter. I find out that there is no voltage anymore on the original battery.I replace the battery for a new OEM Battery and the phone turns on again ☺, but he didn’t pass the apple logo. The phone stays on and only shows the apple logo.I connect the phone to Itunes and try restore the phone with recovery mode and dfu mode, I get the message error 6. I open the phone again and disconnect the rear camera and proximity sensor and try to restore again with no lock. I try different original apple usb cable and difference usb ports but with no luck.
I think there’s a broken component on the motherboard that need to be replace, but I don’t know where I need to start.
Can someone help me with this problem?
By the Way sorry for my bad English.
Best regards,
Marvin
Questa è una buona domanda?
Punteggio 1
2 Commenti
Did you try another battery? The replacement battery quality is so bad in the market. Also, the replacement battery may need time to charge up depending on how low it was when you installed it. A bad battery has been the culprit for a Apple logo sticking or a boot loop, in the past.
da
Yes I try 3 differents batteries
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
I'm starting to wonder if there's a soldering connection that needs to be reflowed. Particularly on the u2ic
Punteggio 1
4 Commenti:
if it's the u2ic the phone still need to boot when the battery is not empty right?
da
Yeh. The u2ic helps the battery charge. No u2ic. No power to battery
da
I think it's the u2ic. I heat little bit the u2ic with the hot air and the phone charge again for 2 minutes, after that the phone doesn't charge again. For now i don't change the u2ic because I don't have enough skill on this moment.
da
Skill and good tools are a big necessity
da
Aggiungi la tua risposta
Marvin sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 855
