Salta al contenuto principale
The following information is intended to help service the Nerf N-Strike Elite Strongarm . The Strongarm was released in 2013 by Hasbro under their Nerf brand.
My strongarms trigger feels too tight in single fire
i bought my strongarm a few days ago and i must say it is a great gun. it even works flawlessly with the ranges to be expected. the slam firing works seemlessly and im happy about it. but when i try single fire the trigger is very tight so its almost impossible to shoot with 1 finger. you have to press back reallly hard for the gun to shoot. but if i havent pulled back the slide before pulling the trigger, then the trigger isnt that tight at all. the problem is only when i have pulled back the slide until it clicks and then i try to shoot . but it does shoot the problems is i need a lot of force to shoot it, which i dont find normal.
thank you
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
3 Risposte
Risposta Più Utile
This problem might be occurring due to the spring attached to the trigger being misaligned.
Punteggio 1
1 Commento:
helpfull guy
da
Mine's got the same problem!!
It damaged the very day I bought it!!
Punteggio 0
Thanks I had the same problem then I read Jaden abbots comment and fixed it p.s. I am a minor
Punteggio 0
1 Commento:
wait mine was made in 2011
da
Aggiungi la tua risposta
bob sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 639
