Salta al contenuto principale
La HP Color LaserJet CP1215 è una stampante laser monofunzione commercializzata per piccole aziende e uffici domestici.
Printer doesn't grab paper anymore
The printer seems to damage the paper on top center, this results into no paper being grabbed, and thus nothing being printed.
This occurs after the first page is printed. So the fist page is not an issue.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
You can Try if the Problem is still there when you put in like 200 Papers, and if it is the same when you put in only 20 Papers.
Most Times the Problem is the Mechanics that pulls down the Rolls for Grabbing the Paper.
This Mechanics can not work this Exactly when the Printer is used very often, or the Printer ist getting Older. It is a normal Process in Older Printers.
Punteggio 0
Aggiungi la tua risposta
Dries Coupe sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 7
Tutti i Tempi: 610
