Salta al contenuto principale
1.83 GHz Core Duo or 1.83, 2, or 2.16 GHz Core 2 Duo A1208 (EMC 2104/2110/2114/2124)
201 Domande Visualizza tutte
excessive noise from coolers after replacing hdd
The new HDD is installed on the imac has no temperature sensor connector and cable leave that loose. That is not connected. I closed the imac and OSX install correctly. But the problem is that the cooler makes excessive noise. Probe smcFanControl or programs like fancontrol but I had the solution. I recommend doing to fix this problem?
Best Regards!
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Risposta Più Utile
Replace the temperature sensor. Apple part #922-7242. iFixit does not carry this part. You can get one from Welovemacs for $59.95: http://www.welovemacs.com/9227242.html
or from me for $35.00 (click on my icon and email me)
Punteggio 4
2 Commenti:
There is software called HDD Fan Control designed to fix this problem, it uses SMART to track the drives temperature instead of the sensor, and does control the fan correctly
www.hddfancontrol.com
Works great
Punteggio 1
Aggiungi la tua risposta
Gustavo sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,411
