Salta al contenuto principale
This affordable large-screen Android phone sports a 5.7-inch display and large 3,400 mAh battery.
218 Domande Visualizza tutte
Why did my ZTE zmax not turn on after made it restart?
So I restarted my phone because it was having issues charging and now it won't turn on so i'm not sure what to do and there's no poutside reset thing. i've tried plugging it into the charger but it had 70-80 % left and the screen it still black it's plugged into the charger.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi,
Try performing a master reset using the hardware keys. This is also known as a hard reset.
Be aware that a hard reset will erase all your user data and downloaded apps. It will restore your phone to a factory default condition. It will be like when you first bought it.
Before you perform a hard reset:
Ensure that the battery is charged (80% is good enough).
Do not leave the charger plugged in while performing a hard reset.
Remove the external SD Card (if installed).
Here is a link that shows how to perform a master reset. Scroll down to Master Reset with Hardware Keys to see how to do it.
https://support.t-mobile.com/docs/DOC-15...
Be patient it takes a little while to complete a reset.
Punteggio 3
Aggiungi la tua risposta
Joy McDaniel sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 131
