Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1688/A1633. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 32, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
2690 Domande Visualizza tutte
Domanda Chiusa
Home Button Replacement Problem
I got a new home button and metal bracket. I can assemble the parts no problem but I cannot click the home button. It seems as if the metal bracket and the button click part are to close together
I tried 2 home buttons, one from eBay and one from amazon. The bracket I got from IFIXIT. Has anyone ever had this problem, I just cant figure it out. I've taken off and replaced countless home buttons on iPhone 5's and even a I6 and never had this problem.
Questa è una buona domanda?
Punteggio 0
1 Commento:
Check if the metal bracket is flat and not bent and the correct screws are used to hold the metal plate behind the home button.
da
Aggiungi un commento
1 Risposta
Loosen the screws a bit till the button clicks.
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 122
