Salta al contenuto principale
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Domande Visualizza tutte
Letter "T" capitalized works only if I press the Caps Lock key
Hi
Macbook White a1181 2GHz Core 2 Duo mid 2007.
All keyboard keys are working fine -both uppercase and lowercase- except when I try to write the capital "T".
If I press "shift + T" keys, don't write anything. The only way to write a capital "T" is by pressing the Caps Lock key + "T" key. (the "t" lower-case letter is working fine)
All the other keys and functions on the keyboard are working fine. I have replaced the silver Upper Case Cable, but no success.
Connecting an external USB keyboard everything works fine.
Do you have any idea about this strange issue?
Thanks!
Questa è una buona domanda?
Punteggio 2
2 Commenti
Question: Is it both Shift Keys that do not work with the "T" or just one?
da
Hi Brian.
Honestly, until reading your comments, I had not thought to check the right-hand Shift Key. And yes, pressing the right-hand Shift Key I get to write a capital "T" !!
Thanks Brian!
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
Yes, you do have a very odd condition! I suspect the encoder chip logic which is part of the upper case is damaged somehow (did you spill something into the keyboard).
I would just replace the upper case assembly here: MacBook Santa Rosa/Penryn Upper Case with Keyboard. Follow this IFIXIT guide: MacBook Core 2 Duo Upper Case Replacement
Immagine MacBook Santa Rosa/Penryn Upper Case with Keyboard
Prodotto
$119.99
Punteggio 3
3 Commenti:
Thanks Dan!
This is a second hand macbook, so I do not know what happened in the past.
That "encoder chip" to which you refer, is the one located on a small board under the trackpad?
If so, is there any easy way of replacing just that small board? ....because this macbook has a spanish keyboard and I would like to keep the same arrangement of keys on the keyboard.
thanks!
da
mmm ... Sadly, you can't buy the circuit board alone. But, you could try transferring it from the replacement case. But, I think it would be smarter just replacing the upper case just to be sure that if it was anything else it too would be replaced.
Look online I'm sure you can find a Spanish version of the part. The Apple P/N is 922-9550 just append the word Spanish in your search. Here's one I found 13" MacBook Keyboard w/Top Case Housing (Spanish) (White).
da
Thanks for the info Dan!
da
I have the SAME symptoms, however a completely different setup! I was using the USB Magic Keyboard (with numeric keypad) with my 2017 Macbook Pro, and it was doing that same thing, however the on-computer keyboard worked normally. I just bought a 2023 Mac Mini M2 Pro -- and it's the SAME thing!! The keyboard is plugged into the Mini's USB-A port, and it sometimes works but usually not.
So, it MUST be the keyboard somehow. I've also noticed that occasionally I hear the mac mini start doing the contiuous "clucking" sound of a key being stuck while I'm not using it, or the Mini waking up on it's own (I have to turn the monitor off, otherwise it blasts my room with light in the middle of the night), so there is something not quite right in the keyboard itself that is causing contact of a key or something.
I'm going to switch to a logitec wireless keyboard and mouse to see if tht works - I hate to give up the Magic Keyboard and but I don't think I want to spend andother $100 plus on one.
Punteggio 0
Aggiungi la tua risposta
aronofski sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,548
