Salta al contenuto principale
Complete disassembly and replacement guides for the Alldaymall A88X 7-inch 8 GB Android Tablet. Repair requires screwdrivers, tweezers, a soldering iron, and prying tools.
9 Domande Visualizza tutte
Domanda Chiusa
Volume buttons are unresponsive.
Hi, I have an Alldaymall A88X and the volume buttons are unresponsive. I can turn the device on and both the touch screen and the power button work flawlessly. I can change the volume through the settings but when I attempt to change the volume using the physical buttons on the side of the device nothing happens.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
if your power button is unresponsive it may have become unseated in its housing. To fix this please place two fingers on the volume button and gently rotate them in a circular motion. If you feel the button shift and then lock into place try and see if the button works. If the button does not work after this you may have either a broken or faulty power button. This could mean either the power button cap or the physical switch on the motherboard is broken. Please follow this link to troubleshoot and fix this problem: Alldaymall A88X Troubleshooting.
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 148
