Salta al contenuto principale
Modello versione metà 2009 A1278 - EMC2326 / processore Core 2 Duo 2,26 o 2,53 GHz
745 Domande Visualizza tutte
No LED or charge or power from power adapter
Hi All,
I have been searching for answers and also read through other people posts. Firstly, I am currently in Burma for next 5 months and no Apple shops around here. I only had this macbook for 3 months.
So the problem started when MagSafe looks loose when attached to the dc-in. Like i have to move a little bit or press it. After 4 days later, its completely dead. No LED or anything at all. I have cleaned both sides of magsafe with cottons and doesn't help.
It would be really helpful if I can troubleshoot myself which part is really broken. Example, testing the voltage of the power adapter or if there is any defect with dc-in adapter.. I can easily order dc-in from Singapore but I kinda want to make sure that is the problem.
Lastly, I am not impressed with Apple having power issues on these expensive laptops.
Thanks in advanced.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
You may still be under warranty. I'd contact Apple here: http://www.apple.com/support/contact/pho...
Do you get a light on the Adapter when it's plugged in?
Punteggio 2
3 Commenti:
"No LED or anything at all."
da
Worth a try. +
da
No light when plugged in. Not even for one sec. Tried to move the plug around a little bit but doesn't help.
No service center in Burma. Only way is to send to Singapore. But I don't think any apple store do international shipping :(
da
Likely the Left i/o board.
Punteggio 1
Aggiungi la tua risposta
diego sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 2,566
