Salta al contenuto principale
Guide per la riparazione delle scarpe e il mantenimento, tieni il tuo paio di scarpe in perfette condizioni.
20 Domande Visualizza tutte
perserving heel and soul using silicone
New boots showing wear after being worn 4 times. Would a coat of silicone protect against wear?
Questa è una buona domanda?
Punteggio 2
1 Commento
I sprayed silicone on the boot material
da
Aggiungi un commento
4 Risposte
Risposta Più Utile
You may be able to use silicone to rebuild your worn outsole, though the success of this repair might depend on the product you are intending to use and the type of material your outsole is made out of (leather, rubber, etc.).
A tried-and-true product specifically used for shoe repair is Shoe Goo. Here are two guides to help you complete the repair:
Hope this helps!
Immagine Shoe
Guida
How To Fix a Hole in the Sole of a Adidas Gazelles Shoe
Difficoltà:
Moderato
30 minutes
Immagine Shoe
Guida
Come riparare un buco nella suola della scarpa
Difficoltà:
Molto facile
15 minutes
Punteggio 4
If these are leather you can use several things:
These are made of hard plastic:
http://www.amazon.com/Traveler-Plates-Na...
These are nylon:
http://www.ebay.com/itm/10-pr-Guard-Heel...
These are metal:
http://www.ebay.com/itm/DIY-metal-BIKER-...
These are hob nails, worked well for the German army:
http://www.najecki.com/repro/shoes/Hobna...
Punteggio 4
Here's something you might try. A bit costly I admit, but your shoes will wear down the pavement instead of the other way round ;)
(sorry, couldn't resist)
Punteggio 2
2 Commenti:
You dont want to walk on any glass floors with those shoes
da
"In these shoes?? Let's do it!!"
https://youtu.be/9qoivS9nbrc
da
我不知道!我不知道!我不知道!我不知道!我不知道!我不知道00!
Punteggio 0
1 Commento:
At least you know you dont know
da
Aggiungi la tua risposta
elisabeth sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 17
Tutti i Tempi: 4,245
