Salta al contenuto principale
Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
433 Domande Visualizza tutte
iMac stuck on a white screen, replace the RAM?
Hello,
My current 2008 iMac is not booting and stuck on the white loading screen. I only have 1gb of RAM in the computer and run both windows and OS from it. Do you think upgrading the RAM will solve the issue?
Thanks a lot:
Questa è una buona domanda?
Punteggio 0
1 Commento
Here's the specs for your system: iMac 24" 2.4 GHz Core 2 Duo
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Actually, no. It's probably the hard drive. Try booting from your original system installation disk. Insert the disk on start up, hold down the "C" key, go to the second page pull down menu and run Disk Utilities on the hard drive.
Some more RAM wouldn't hurt at all! You can add just one at a time.
PC2-5300 2 GB RAM Chip
Immagine PC2-5300 2 GB RAM Chip
Prodotto
$14.99
Punteggio 4
1 Commento:
I agree with Mayer here you more likely have a HD issue. But if you are running Window's & Mac OS you should max the memory to 4 GB (Apple's limit) or 6 GB which 3rd parties have found will work. Review the link in your Q for more info.
If your HD is struggling it might make sense upgrading to a SSHD like Seagate's Desktop SSHD. You'll only need the smaller 1 TB drive. Unlike many drives today, you need a drive that runs at SATA II (3.0 Gb/s).
da
Aggiungi la tua risposta
Rishil sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 204
